how do i install PMB on win 7
gunhed127
How do i install PMB software on windows 7 pro 64 bit?.  I have downloaded the 64 bit installer and with the original  cd in any of the dvd roms i have, it fails to find any disc in either of the roms after running the installer
blaireau_photo
Ok thanks for letting me know.
I have highlighted this issue to some colleagues to check if there are any known compatibility issues with this software and Windows 7 64 bit edition to see if there is anything else we can suggest.
Thanks,
Simon
5 REPLIES 5
blaireau_photo
Hello gunhed127 - welcome to the Sony Forums :slight_smile:
First of all, have you tried to download the 32 bit installer instead? You can try installing this in 32 bit compatibility mode to see if the problem is linked to the 64 bit version.
Thanks,
Simon
gunhed127
yes tried the 32 bit installer, didnt work, said it couldnt install program properly
blaireau_photo
Hello,
In Windows 7, when you have the 32 bit installer icon and right click on it, do you select 'troubleshoot compatibility' and let the wizard choose the most appropriate settings?
Simon
gunhed127
yup done that already, says the same thing, program has not installed correctly. same as my original disc
blaireau_photo
Thanks,
Simon
