How to mount the HX60 to a tripod without covering the HDMI port?
djones123
The HDMI port on the HX60 is on the bottom of the camera close to the tripod mount. This means that when the camera is fixed to a tripod in the normal way, using a flat mount, the port is covered and cannot be accessed. I need to use the HDMI port in order to connect a field monitor. What is the best solution to this problem?
Sean_Mc
Moderator
Hi there,
That's a tricky one. I'll have a search and get back to you. Perhaps someone else in the community who uses this camera may have a solution for you.
Best wishes,
Sean Mc
