RX100 MK4 continuous shooting speed
pb.981
Hello,
Does anyone know if it is possible to adjust this? If I set the camera to 'continuous shooting' it takes lots of still pictures very quicky - can I slow it down at all? I've looked through the menus and can't see a setting for this
Tags (2)
Sean_Mc
Moderator
Hi there,
I've had a look through the manual and I don't think it's possible to change the speed as such.  Perhaps someone else in the Community may be able to offer a solution.
Best wishes,
Sean Mc
jazzcaffe
On the mk v if you go right on the wheel after you change from single shot to continuous shooting, there's a mid and low option. This may or may not be available on the mk iv.
pb.981
I can't find this on the Mk4, so it looks like it was introduced with the Mk5. It's not a big problem but I'm just surprised the option isn't there. Thanks for the reply anyway!
