Sony cam
Kingchris100
Sony cam
Was wondering when recording in the high mode for vids how can you transfer them to another device without loosing the quality I have recored them in
Pascale_F
Moderator
Hi Chris,
Welcome to the community. Are you able to give us a bit more info? Which camcorder do you have and which device are you trying to transfer your videos to?
Thanks,
Pascale
Kingchris100
Dsc x90 camera when I'm taking the highest quaily video I can't transfer it to say a smart phone I want to able to do that without having to put it in mp4 format  if this makes sence
IamNic
Hi @Kingchris100,
if your smartphone can play the original-file, you can simply copy it to your smartphones SD card.
 - Nic
