Workshy1
Video FR
Hi all, new to this forum and to video...or at least I now realise how new I am to video having blundered on for a couple of years with a camcorder, now have a shiny new bridge camera which I have yet to find its, hopefull potential!
If someone can answer this I would be gratefull; If 60P is smoother and better for action, and presumably therefore wildlife film, why is it not better for all types, normal, fairly action-less movies? Or is it just that it takes more memory, or bitrate, or something and is therefore wasted as no noticable difference would be seen?
Mick_D
Moderator
That's pretty much it! You can use more than twice the camera (and computer) 'resources' to capture and edit footage at 60p. At 4K resolution that can be a substantial amount of data... the best advice is to shoot at high resolution as much as possible, but restrict high frame rate capture to fast-action (or slow-motion) footage.
Hope that answers your question :cool:
Mick
Mick_D
Moderator
Mick
Workshy1
Ah-ha. Thank you.
Regards
Mark
