how to store photos to sd card in xperia E,camera showing no option for the storage of pictures and videos?i have no sd crd mounted the photos and videos going into the phone memomry,Any option to change the default storage location ?
Solved! Go to Solution.
on other Xperias like the Xperia Z
open the Camera app > settings > data storage > SD card
If you don't see that option then this feature its not available on this Xperia.
Don't forget to give Kudos
Camera app has no SETTINGS option !!! it or may be after inserting sd card it willl show ?
WOOOHOO Ifound it in camera mode tapping the menu button it shows storage and other options
That language its NOT tolerated.
settings its a wrench / screwdriver icon
Told you, don't forget to give Kudos
