Dilipmtech
dial pad problem
hi everyone i found no problem until yesterday the problem is with dialing number... each time i call to some number it diverts to one particular last called number and so i tried to call from choosing contact names still it diverts to last called number for instance if i choose to call madhu from contact list it diverts to particular number last call in recent calls. i also tried *123#  still sa,e problem  please tell me whats the solution thanks in advance
discretion1
If it doesn't solve the problem, try this. First, backup your contacts to your sim card or sd card: Contacts--menu--Backup contacts--Sim card or Memory card (Memory card would be better). Then try clearing data at: Settings--Apps--All--Phone--Clear data, and similarly for Phone contact and Phone/Messaging storage apps. This will delete all your preferences for the apps and also the contacts stored in the phone. Reboot. Import contacts back to phone: Contacts--menu--Import. See if problem persists.
discretion1
Clear log and try dialing then. Dialer--tap menu -- Clear call log. If it doesn't work, reboot.
discretion1
Dilipmtech
actually i installed one security app which will call mentioned number  if u change the sim card and eventually asi cleared the data it got deleted  now wokrking good
