I have recently purchased, second hand a PRS 300. I have managed to download a couple of free books, but I have recently borrowed some from my local library and installed them on my e reader library, but when I try to transfer to my reader I get the message ' this ebook cannot be transferred because the reader is authorized to another user' Can anyone please help, many thanks. Bob
The reader is authorized with old user's Adobe ID. I don't know how you can de-authorize the reader (it needs old user for doing this). Probably, formatting internal memory will de-authorize the reader, but in this way, all contents on the reader will be erased.
But I think that's possible, as with the new readers (PRS-T1 or T2), change the authorization even without de-authorize previously the device. You have to connect the reader with a PC(Mac) authorized with your Adobe ID and with the "Reader for PC(Mac)" installed.
http://www.sony.co.uk/support/en/product/PRS-300/downloads/SWupdate_Reader_PC_v2002_15180
Attention!!! After reader's authorization with your Adobe ID, all old contents on reader authorized with the old user's Adobe ID will not be "readable" anymore.
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
