Help fixing Sony PRS-T2
Hi there,
Thanks for taking the time to read this.
I've had my Sony PRS-T2 for over a year now and never had any problems with it until the other day it froze.
I read it on my break and work and it was fine, then when I came back to read it again at lunch it wouldn't work.
I'm wondering if this is a fixable problem or if I have to buy a new ereader - which I don't really want to do.
Attached are two photos of the problem, the first (showing A Clash of Kings) when the problem started, the second (a shot of the library taken today).
Any help is much appreciated.
Hi Highwalker and welcome.
Sadly, it looks like a screen harware problem which may be uneconomical to repair.
Have you tried: - A Soft Reset?
A Hard Reset? - this will delete everything.
You could try phoning Sony Support to ask for a repair estimate - always worth a try.
:thinking:
