AV messges on a Bravia
Rusty748
I am getting messages in top left of my Bravia TV model no KDL - 32S3000 screen differing each time I turn it on, how do I get rid of it, it is annoying! :-
AV4
arrow right, small tv screen containg three dots then 4
1080i/50
next time it will be
AV2
arrow right, small screen blank then 2
next time it is as the first one above but the top line reads tuner 1 instead of AV
The_Black_Rose
Specialist
Hi Rusty748,
I was referring to the button labelled 21 on page 9 of the Manual, available through this link http://bit.ly/2XSh6mM. Could you give that one a go and let me know if the info banner appears again?
Cheers,
The_Black_Rose
6 REPLIES 6
Pascale_F
Moderator
Hi Rusty748,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Rusty748,
I think you're referring to the info banner that appear whenever the signal is changed. You can remove this by pressing on the i+ button on the remote control.
Cheers,
The_Black_Rose
Rusty748
Hi Black Rose, thanks for reply. Unfortunately these messages do not go away when I press 'i' button on my remote, all that does is bring up details of the proramme I am watching. There is no  'i+' button on my remote. The messages don't always change when I change channels and the only messages I get are the 3 shown - none other! Is 1080i/50 something to do with picture definition or suze?
The_Black_Rose
Specialist
Hi Rusty748,
Cheers,
The_Black_Rose
Rusty748
Hello The_Black_Rose,
Brilliant solution to my problem - many thanks. Worked first time, we have two remotes and I used the button on the non BT vision signal while watching TV on BT vision.
The_Black_Rose
Specialist
Hi Rusty748,
That's really good to hear. I'm glad I could help.
Cheers,
The_Black_Rose
