digital channels
profile.country.SE.title
ali.electro
digital channels
Hello,
I have following TV model : Sony 48 "LED Smart TV KDL-48W605BBAE
it supports
DVBC / T2 / S2
Also it supports:
Approved by BoxerYes
Approved by Com HemYes
Approved by Canal Digital KabelYes
Approved by Canal Digital SatelliteYes
But I still dont get default channels in my TV. I live in Sweden. Can someone please point me out some settings in my TV which I am missing?
17 REPLIES 17
IamNic
Hi @ali.electro,
did you perform this step when setting up your TV?
- Nic
ali.electro
yes i am doing the same pic attached. no channels found yet.35306030_10155691674661342_822758705614290944_n.jpg
IamNic
Hi @ali.electro,
did you check if the cable is connected properly to the TV? (At least it looks properly attached on the image you uploaded)
Also did it work with your previous TV?
- Nic
ali.electro
yes it looks to be connected OK.
I had same TV at previous place where I lived, but there the provider was different it was comhem and i had white cable there also but it wasnt same as this ( it was something which comes along with internet connection)
I have a different provider "Boxer" here.
In my previous place it worked fine with this TV.
IamNic
Hello @ali.electro,
would you mind explaining the difference between the providers?
Your old one seems to have been a cable provider, your new one is DVB-T?
- Nic
ali.electro
both of them are ISP.
They provide internet as well as digital TV
https://www.boxer.se
https://www.comhem.se/
IamNic
Hi @ali.electro,
does Boxer need this little receiver to work (the one shown on their website)?
If not, why don't you give them a call and explain that you have problems setting your new TV up.
- Nic
ali.electro
yes I am thinking of calling them now.
thanks for ur quick suggestions :slight_smile:
