MAX IMAGE FILE SIZE ELEMENTS COMP ?
leotroll
Hello everyone. I can't seem to find the maximum image file size for the elements competition ,i'm sure it was 5mb max in last competiton,but then again i may be mixing it up with another competition. Be very grateful if some one could enlighten me .
        Regards Steve.:confused:
Peter_S.
Genius
Hi Steve,
Max image size for galleries is 5 MB - this also applies to competitions.
Peter
Peter_S.
Genius
Hi Steve,
Peter
leotroll
Thanks a lot.:smiley:Must have been on the gallery i saw it before ,it tells you minimum image size but not maximum file size in competition rules.maybe needs including on competition page. Thanks again.
