My Sony App
bobley50
My Sony App
Hi
This is my first post so hope it is the right place.
I have the "MYSONY" app on my Iphone 6s but need to delete some of
the registered items that are showing.
Does anyone know how this is done.
I can see how new purchases can be added easily enough, but I cannot see any way to delete
equipment you no longer have through the app.  Do i need to do this from some other site
Many thanks for your help
Regards
Bobley50
cass_n
Community Team
Hi @bobley50,
You will need to tap and hold the product until a tick mark appears, and then tap the trash can (top right) to remove the product.
Please see the screen shot attached (apologies for the German language).
I hope this helps.
Cheers,
Cass
cass_n
Community Team
Hi @bobley50,
I hope this helps.
Cheers,
Cass
