Software
carolghamilton
Software
I can see what software version is installed on my TV but how do I check whether it is the most up to date version available? tV model is KDL-32R433B
Thsnks
EdwinaU
Moderator
Hi Carol,
Welcome to the community.
You can check the latest software versions for your TV here.
Best wishes,
Ed
carolghamilton
Thanks Ed. I think it must be me, but I’ve already looked at that page and cant see anything about current software. Maybe the tv model doesn’t support this?
EdwinaU
Moderator
Hi Carol, the latest firmware updates  will be on that page so it's likely that you are up to date. However,
you can also contact support using the information on there if you need further advice.
Best wishes,
Ed
