Hello.
Can You Please Advise Me The Fuse Rating 3 Or 5 Amp For Mains Plug . Voltage 220 To 240 AC Moulded Plug.
Thanks. George.
Solved! Go to Solution.
Thanks For Help With Fuse Type Player Is Now And Running No problembs.
Regards.
George.
Hi George,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Thanks Pascal.
Think a 3amp Fuse is Suitable For The Mains Lead plug. But Will Wait a While To See If Its Suitable.
Thanks.
George.
Thanks Pascale.
Regards.
George.
Hi Batee5
Thanks For Info On Fuse Rating On Player. Will Order One Up.
Regards.
George.
Thanks For Help Blu Ray Player Is Now And Running. No Problembs So Far.
Regards.
George.
