Sony RX100 VII Memory Card question
SoKneeRX
What is the fastest recommended memory card for the RX100 VII?
Win_88
Specialist
Hi SoKneeRX
I found a section in the help guide where Sony lists the types of memory cards that can be used but there isn't mention of maximum read/write speed:
https://helpguide.sony.net/dsc/1920/v1/en/contents/TP0001140402.html
Win_88
Sean_Mc
Moderator
Hi there,
If you take a look on the product page for the RX100 VII, under Full Specifications & Features you'll see more details on what memory cards are compatible with this camera.
Best wishes,
Sean
SoKneeRX
Hi Sean
Thank you for your advice, I downloaded the manual for the camera but I was unable to find any mention about the maximum memory card speed specifications.
There are many different speeds available, the one recommended with the package was a Sandisk Extreme 90MB/s SDHC UHS-I. What I would like to know in advance if possible is whether it is better to buy a memory card with a much faster read and write speed from the start without buying the recommended speed only to find out afterwards that camera is capable of supporting something much faster.
The Sony website doesn’t appear to mention anything but if users of the previous model already know that the camera does take advantage of something faster then it makes sense to buy the better one from the start.
John
Win_88
Specialist
Hi SoKneeRX
Win_88
