Hi I have a sony hcd hx80r system could I use 2 Sony TS-XTS31 speakers which are 2.5 ohms instead of the 6 ohm speakers that came with the sony hcd hx80r system
Thank you
Hi Smrala,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Smrala,
The impedance of the CMT-HX80R is 6 ohms, so it isn't really recommended to use 2.5-ohm speakers. To be honest, I don't really think it'll work.
Cheers,
The_Black_Rose
