Update
Betty-boop1977
Update
Can anyone tell me what the 5 next to my WiFi icon is only appeared after the update I did today
8 REPLIES 8
Betty-boop1977
If anyone else has it could you please tell me what it's for thanks
Joe_Dohn
Specialist
What device are you referring to and what software update did you install?
Including a picture of what you're referring to would also be helpful ^^
- JD
Betty-boop1977
I've got a song Experia 1 and it  was a system update ,the other day the was a 5 next to the WiFi icon now it's a 4  you can see the 4 injust don't know what it's for
EMS_MO72
Community Team
Hey the numbers beside Wi-Fi signal signifies the Wi-Fi standards, so 4 means that the means that the Wi-Fi operates in the 2.4/5 GHz frequency range only , it;s mainly something related to the Wi-Fi signal on your device.
Betty-boop1977
Thank you ,could you tell me why it goes from 4 to 5 thank you again for the reply
EMS_MO72
Community Team
I think the phone automatically connects to the best available frequency which is the 5Ghz, but that can be controlled from the router if you want to enable both of the frequencies and the phone will connect to the best available one or just enable one of them to be the permanent frequency.
Betty-boop1977
Thank you so much I understand now ,
EMS_MO72
Community Team
You are most welcome.
