CMT-SBT20B headphone issue
bobladdie
Is there any way of using headphones with this system? Just had it as a Christmas present with the intention of quiet listening so its a bit useless.
Joe_Dohn
Specialist
According to the Manual (page 23), the system can't connect to Bluetooth speakers, which means it doesn't support Bluetooth transmission, only acts as a receiver for phones, laptops, etc.
joejoe66
Yea they don,t tell you that when buying it do they, no info about that on packaging, i have the same problem a hi fi that i cannot use head phones with so is practicaly useless to me, SHAME ON YOU SONY, wont buy your products or recommend them.
Bat_Rick
Hi Bobladdie,
According to the manual, this is not possible :(.
