Sony micro hi fi CMT-G2BNiP
Peacejohn51
After not using my hi fi for over a year, I plugged in switched on ,pressed standby which turned orange then green, showed volume and station 3 seconds later came up PROTECT then shuts down.
this hi fi was working fine previously.
can anyone help?
Piscie
Community Team
Hey @Peacejohn51,
As per the device manual, This message is displayed along with the sound interruption when you turn up the volume during playback of a CD with a recording level that is too loud, or when you play back a CD which contains input signals that are too large, try to adjust the volume using the VOLUME or Bass/Treble to turn off the message.
Hope that works. :slight_smile:
