HAP Music Transfer for Windows
jowagst23
Has anyone tried or can anyone confirm if the HAP Music Transfer Software for Windows will work with the sony gigajuke nas-sc500pk music server?
Has anyone tried using a Bluetooth usb adapter to transfer music to the gigajuke nas-sc500pk from a pc with any success?
Any advice will be much appreciated.
John
4 REPLIES 4
Pascale_F
Moderator
Hi jowagst23,
I'll see if i can track down an answer for you about this. Maybe someone else in the Community has an idea in the meantime.
Thanks,
Pascale
jowagst23
Hi Pascale_F
Thank you for your reply, I would be very grateful to receive any advice as to how music can be transferred from  a PC to the sony gigajuke nas-sc500pk music server rather than using a walkman, usb drive, etc.
Regards,
John
batee5
Specialist
Hi John,
I dug through the operating instructions manual of the Giga Juke and found that there are detailed instructions on how to transfer or import media files from a computer. You'll find them starting page 59 on this link: https://bit.ly/2KKHKHs.
Hope this helps.
Regards,
Batee5
jowagst23
Hi Batee5,
Thanks for your reply.  I am aware of this and used it when I had windows xp. However after upgrading to windows 8 the music transfer software became incompatible and sony did not offer any upgrade to cover this.  I used the windows compatibility assistant for installing old programs but this doesn't work either. The same applies to windows 10.
