Soundbar
lindarhead
Soundbar
I bought a Sony Bravia TV on Friday ,the KD-49XE7002  , and was wondering if anyone could recommend a decent sound bar that’s reasonably priced?
IamNic
Hi @lindarhead,
that depends on how you define "reasonably priced" :yahoo:
There are many good soundbars, yet you need to be a little bit more specific.
Is 2.0 sufficient or do you need rear speakers as well to get 5.0 sound. How about a subwoofer as well?
I personally own the HT-RT3 and I am very happy with it. I though use it without the rear speakers currently, since I moved the sound system to another room where I don't have any option to mount the rear speakers.
I can highly recommend to take a look at all the available Sony soundbars on this site: https://www.sony.co.uk/electronics/audio-home-cinema/t/sound-bars
- Nic
