USB Bluetooth dongle with LDAC support for WH-1000XM3
tnx.cz
Hello.
If I connect Sony WH-1000XM3 to computer via bluetooth, the sound quality is very poor because it lacks support for LDAC or APTx HD. Is there any USB bluetooth dongle with LDAC support on the market that would allow me to conect Sony WH-1000XM3 to computer and listen to music from computer without sacrificing sound quality? I can listen to music from mobile phone, but then I miss sound notification from computer. I was searching for few weeks, but there are some LDAP receivers but no transmitter. Has anyone seen such product?
Thank you
Jan Kovar
4 REPLIES 4
Pascale_F
Moderator
Hi Jan,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi tnx.cz.
I believe that using an external adaptor is not always recommended by manufacturers as their functionality can't be guaranteed.
Cheers,
The_Black_Rose
fraroess5
Using a common standard as LDAC is not recommanded as it is not guaranteed that all suppliers fullfill it.
Cheers!!!
If there're are no usefull transmitters (USB BT dongle, no alalogue connected transmitters), this "standard" won't become a known and used standard.
The problem is the massive lack of usefull hardware to drive Sony BT headphones.
SMTguru
Welcome to 2023
https://www.bluetoothgoodies.com/a2dp/
It works great for me.
