Wx-800ui
Ricki69
Wx-800ui
Downloaded the new software but won’t install
jumpsuit
Hi @Ricki69 and welcome to the Community :slight_smile:
Are trying to install the version .12 update?
If so there is a guide Here just so you can check
you followed all the procedures.
Hope this helps.
Glimmermant21
Hi there I have also downloaded this update, problem is that due to the buttons freezing up and have disconnected the stereo many times. I am unable to install the update. All the years I have been buying headunits this is the first time ever I have had an issue.
