BDP-S1100
BDP-S1100
I have the bluray/dvd/Internet player but I live with my parent's at the moment so I cant exactly have a Lan wire travelling from bedrooms so im wondering if there is any other way I can connect it to the Internet. Gutter I can't use it 😞 someone tell me there's a solution haha! Thank you :slight_smile: xx
Hi there
The solution is Homeplugs : HERE
They work using the existing electrical powerpoints.  You connect one to the powerpoint at the router end, and the other at the bluray player end, then "pair" them together.  Have a look anyhow.
Hi there
