Help?? I have just purchased a Hard Disk Recorder and want to know how to input the four-digit passwork to use on the system menu as the instruction manual doesn't tell you?
Hi Janet2201,
The default password is 0 0 0 0 if you are asked for a password and have not set one up. Just press the numbers on the Remote Control.
Is it the Parental Control password you want to set?
