I have recently purchased a Sony HT-AS5 Home Cinema system and I have some questions about setting it up:
Thank you to anyone who can provide some answers and guidance.
if your tv supports the Audio Return Channel (ARC) then connect the tv to this that way, your blu ray player, well i do this, connect using an HDMI cable and feed the sound with a digital coaxial cable, for short runs you can use either coax or optical it does not really matter, sound field, well it does Dolby Digital and DTS, so you should be able to set it in the menu, dolby digital to dolby digital and dts to dts and just set downmix to stereo and that should just about cover it.
Thank you for this, but I didn't really understand any of it and it doesn't seem to address my questions specifically.
it seems your best bet is to connect from blu ray player via a hdmi lead to the blu ray connection at the rear of the ht-as5 this will provide audio and video also before using ht-as5 calibrate speakers using supplied mic take care when using mic insert into correct jack audio field can be altered using remote hdmi lead from ht-as5 should be connected to arc on tv
