HT-CT660 sound bar - sound control from Sky remote
anbarke11
Could anyone advise as to how I can control the sound on my new Sony HT-CT660 sound bar using my Sky remote? If possible, what is the code? The supplied paper instructions are frankly baffling. Thanks.
Mr_Onion
I have had a quick Google, and the codes SONY use appear to be 1086 or 1186 or 1286 or 1786
instructions on how to input the codes are HERE
4 REPLIES 4
Mr_Onion
anbarke11
Much appreciated. I'll try that. Thank you.
None of these codes have worked, tried these and more from online but nothing worked. I am frustrated simply because I had it working before now.
HELP!!
Hazelw79
Did you find a solution?..i have the same issue, it DID work - not now tho.
