Which Player to Buy
Which Player to Buy
I am looking to buy a 4 k blu ray player, I also have a lot of older dvds from around the globe. Do any of the new players support the DVD's from different regions?
Any advice would be helpful as I am not good with this kind of thing. Thanks
Hi there,
You can find the current line up here.
If you check the Full Specifications tab, you can see the playback options.
Let us know which one you go for.
Best wishes,
M
