HT-XT3 HDMI ARC Problem
SteveW60
I cannot get any sound from the HT-XT3 when connecting to my Bravia KD-49X8005C TV using HDMI ARC. The only way I can get it to work is with the optical cable connection. What could be wrong?
Hi there
Assuming that you have connected it to the HDMI-ARC port on the TV, it could be the HDMI cable itself - so, if the below instructions dont work, try a new hdmi cable.
It could also be a HDMI handshake issue, because you plugged it in when the tv was on. Try this:
  1. Turn TV completely off from the wall.
  2. Unplug optical cable, and plug in the HDMI cable to the correct ports.
  3. Turn TV on and test.
Hi there
SteveW60
Hi
Many thanks, turning off at the wall and starting again worked.
Steve
