I own an RDR-HX650 HDD recorder. Is it possible to upgrade it with a built-in digital tuner (MPEG4)?
no way, the only recorder that support DTV are the hxD series (and the newer DC). you can still use an external receiver connected via scart but you have to setup the g-link connection or synchronize it manually for each recording (setting the channel you want to record). you won't be able to use the guideplus feature too.
Kan jeg opgradere rdr-hx650 til ( MPEG4), da jeg er meget glad for min video.
