KP-41DS1 DIGITAL TUNING
SONYKP-41DS1
KP-41DS1 DIGITAL TUNING TV WONT PICK UP DIGITAL SIGNALS
Catmambo
Hi
This panel is one of the models which is incompatible post switchover unfortunately ( the split-nit issue)- www.digitaluk.co.uk/2kequipment
So you'll need to get a Freeview Set-top box or maybe a good excuse to upgrade to an newer model.
Catmambo
Hi
