Loss of SERIES RECORDING option on RDR-HXD870
rjward
Since the recent EPG problems and upgrading the firmware to v1.70 on my RDR-HXD870, I have lost the series recording option on the timer setting.  It used to be there at the bottom of the Set Details options list.  Now it does not appear at all. Any suggestions on how to get it back?
Mr_Onion
Try running the firmware update again.
Mr_Onion
rjward
Many thanks for your help. It worked a treat.
Mr_Onion
No problem. Glad it worked.
