Since the recent EPG problems and upgrading the firmware to v1.70 on my RDR-HXD870, I have lost the series recording option on the timer setting. It used to be there at the bottom of the Set Details options list. Now it does not appear at all. Any suggestions on how to get it back?
Solved! Go to Solution.
Many thanks for your help. It worked a treat.
No problem. Glad it worked.
