Playback problem with SVR-HDT500 recorder
jmcknit
Recently bought - a SVR-HDT500 recorder connected to a KDL-32HX753 TV with HDMI cables.
Playback on the recorder is jerky and sound is not in sync, the screen often blacks out and starts again.  Tried different HDMI slots but makes no difference.  Sometimes when I play the recorded programme again the programme is perfect so obviously the programme recording is fine.  Is this a known playback problem?
Catmambo
Hi
Have you downloaded the latest firmware update for the SVR? May well resolve the problem.
thanks
Catmambo
Hi
thanks
jmcknit
Hi
I downloaded and installed the firmware update.  Playback perfect.  So hope this solves the problem.
Many thanks for the advice.
