I have just bought a BDV-L600 Home Cinema unit. I wish to program my Sky + remote control to be able to adjust the sound volume. Does anyone know the 4 digit code that I need to key into the Sky remote?
Hi mpiercy,
welcome to Questions & Answers..
Have you checked the Sky site's Find your remote control code - http://www.sky.com/helpcentre/tv/remote-controls/operate-tv-with-sky-remote/
Hi, Thanks for the suggestion, but I had already tried this Sky site and it does not recognise the BDV-L600 and just suggests some generic codes that do not work. I suspect the Sky page only knows about TVs as there are no options in the drop down box for Home Cinema devices.
I guessed that may be the case & I'm not sure if the Sky remotes work with anything other than TV's..
Have you tried contacting Sky support.?
I think they should work with any infra-red controlled device - it's just a question of knowing which code to use. I'll try asking Sky support. Thanks for your advice.
