Whats the best way/system to connect my home cinema speakers wirelessly? I have the BDV-E190 system
kurob60
Have just received my new system and want to connect just the rear speakers wirelessly. Have a laminate floor and so hiding the cables is an issue (and a trip hazard)
Bravia55HX
im afraid you cant connect the rears wirelessly it says this also in the specs, if you have laminate flooring you may be able to lose the wires in the expansion gap around the edge of the room.
kurob60
thanks for the answer, will now look to see if the shop will change my system for a Panasonic system. The panasonic system was cheaper but wanted to keep to Sony as I have a Bravia TV. Panasonic system is cheaper as well and can be upgraded to wireless
