I am experience a touch screen error. When I click a point on the screen, other part of the screen is clicked.
How I can calibrate the touch screen?
Solved! Go to Solution.
@shihstouch, thanks for the suggestions and replies.
I have decided to get back to Sony Service Center earlier today, I showed them the video that I recorded when the error comes up. They (Sony Service Center Officer) said that they want to change the screen itself, considering that they don't have anything to calibrate the touchscreen (the officer said so). Yesterday, I have asked them to calibrate the touchscreen, and they said that they are already re-calibrate the touchscreen, it is wasting my time for 3 hours. Today I know that they are lying to me, as they said they don't have anything to calibrate the touchscreen.
I have made my decision. Come to Sony Service Center is such a waste. Wasting my money, wasting my time, and also wasting my energy, so I decided to sell that phone instead of fixing it.
Actually, this is the first time I use Sony's Smart Phone after long time ago using Sony Ericson Feature Phone. I definitely won't buy any Sony mobile phone again.
SOLUTION
If you have the same problem as I experienced and if it is can not be solved using SUS or PCC, just sell your phone. Buy the new one.
You have to take your phone to a Sony repair center, before you do so, repair your phone with SUS or PCC
Don't forget to give Kudos
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
Open Dialer and type *#*#7378423#*#*
It will open Service Menu > Click Service test > ( You have all option to test your phone )
I have tried Sony Update Service, PC Companion, and already go to Sony Service Center. They wiped my mobile phone. In someway, the problem is fixed. But in another way, it is not.
For example (see my screenshot):
Screenshot: https://www.dropbox.com/s/ijptzgjsywdhhvo/Screenshot_2013-09-10-19-05-22.png
When I swipe to left or right the on that menu, it is clicked.
This can be done accidentally, but I am sure that this is not only happen once.
Every time I swipe, it always clicked.
What I can do to fix this?
Did you perform a service test ?
@shihstouch, Yes. If the USB plugged in to my PC, the touchscreen test will be messed up. Otherwise, it should be fine. BUT, in someway, an app always open when I swipe my fingers on the menu (see this screenshot: https://www.dropbox.com/s/ijptzgjsywdhhvo/Screenshot_2013-09-10-19-05-22.png)
I prefer you to remove APPS like...
Task manager
Memory Booster / Ram Booster
Antivirus
Any tweak softwares... Such softwares are not necessary ...
Try Booting in Safe Mode and see if you have any issues...
To enable safe mode
Note: To exit safe mode, restart the phone.
@shihstouch What the save mode supposed to do?
Safe mode will boot your device with factory default Items so you will better know if the problem is causing by a third party app
