The message you are trying to access is permanently deleted.
I dont use the crappy wondoz. So PC companion is not a solution. Do I get the .36 firmware file officially from Sony ?
Solved! Go to Solution.
Looks like I got it. Thanks to AndroidGyan for pointing out
I am also trying to upgrade but can not do it.
I am using version 15.0.a.1.31, the site tells you how the latest 1.36. Any solution for this?
turn on your wifi > settings > about phone > software update
if the update its available in your country then you will be able to update your phone
what's wrong with SUS or PCC or even Bridge?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
keep this in mind
http://www.sonymobile.com/global-en/software/phones/xperia-l/
You may already have the latest software, depending on the date of purchase. Software updates are released at different times depending on operator and/or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device.
Android version: Google Android 4.1 (Jelly Bean)
Latest available software: 15.0.A.1.36
Release started: 2013-06-04
To find your device’s current software version:
Settings > About phone > Build number / version
My Xperia L (C2104) is still onAndroid 4.1.2 & build number is 15.0.A.1.31
I tried checking for update through PC but it doesn't detect any new update at the moment.
Any info on whether the update has been rolled out for devices in india ??
@ashwin21 you are not going to find that info/dates anywhere, you have to wait or manually update your phone
Bridge (for Mac)
SUS PC companion and Bridge works with only windows or Mac. I am on linux
