security code
MSP_Mobile
security code
Hi Every one!
My mobile is asking security password each time when screen is off / on. In the mobile settings for screen lock I have kept "Swipe". This is happening when I upgraded android version to 4.3.
I know the password but it is painful to enter the password each time when your screen is turned on.
Kindly help.
Thank you,
Manohar
13 REPLIES 13
arindampaulju
i have a simpler solution.. if you have changed the sim and tgen it is coming... turn off all security settings.. then switch off n switch on using the ild sim n keep it for some time. then switch off and on with new sim... then turn on all security settings.. it has worked for my set.. try this..
Tirumal
Hi KNSRI
Nice solution.Thank you very much.Saved my time.
Nelii
Thank you so much......Your solution put the nail in the coffin (y)
Tags (1)
preethi123
Dhanyavaadagalu to u!!!!
I was struggling with this issue since Jan this year...I tried ur method of turning off X- Alert in Security settings and also disabled the app in App.
This is an ULTIMATE SOLUTION!!
Thank u sooo much!!!!
