Initial error
An error occurred while preparing to update your device. No changes were made on your device.
Please try again later. If the problem persists, contact Sony support.
Error code: uestartnomoreports
L_2384
Solved! Go to Solution.
I did not try them all.
Hi @kemal81,
Welcome to the community.
If Xperia companion is not working correctly there are a few steps that you can try to resolve this.
Try these methods one after the other. Verify after each method whether the problem was solved, before trying the next one.
How i am gonna get rid from "UELoginNetworkError .nnn.. nnnnn_1210_0" this problem that i am facing during update several times??
yes no problem.
Xperia Companion is running Windows 8 compatible.When the computer from Windows 8 compatibility mode Xperia Companion downlYou can update the tablet. I have not tried it in windows 7. I've tried Windows 10 did. In Windows 10 you say Xperia Companion program I right-click compatibility fix the problem. the problem
Getting Error Error code: UEStartNoMorePorts# L_2384
Found and followed all recommendations at : http://talk.sonymobile.com/t5/Xperia-M4-Aqua/Xperia-Companion-Xperia-M4-Aqua-Update-Problem/m-p/1145...
Internet Access is fine.
Firewall double checked and all necessary items are listed as accessing.
Switched the experia software to run in Windows 8 compatibility mode, and as Admin.
Not using a proxy, but have set the Experia software to automatically detect proxy settings itself.
Only have the most up to date version of Java installed. (currently Version 8 Update 101 64b)
Restarted both after uninstalling ALL java versions and after installing most recent java version.
Still cannot update. Also have fresh restarted the phone.
Any further recommendations?
