arrange icons
mahmoodn
arrange icons
Is there any way to arrange the icons? I have installed some new apps and there are some default apps which I use most. The installed apps are go to the end of list. I have to scroll pages 4 times to reach them
Nabeel
Master
Either arrange them by using options or arrange them manually.
Go to menu and tap on the bottom right icon, all the icons will start jiggling, now tap and hold on icons until it vibrates and drop them on the screen you want to place
Uliwooly
have you tried to open the homelauncher -> tap on the bottom left?
Nabeel
Master
mahmoodn
ok yeah...
thanks. I tapped bottom right button before and saw the icons jiggling. However I thought it was a king of visual effect !!!
:smileygrin:
