The message you are trying to access is permanently deleted.
Hi everyone :
I have this error when updating my xperia to andoid 4 via pc companion...
error : 0x80004005
It's tell me to install SONY UPDATE ENGINE and installed it manually but the error come again...
what should I have to do?
(sorry for my mistakes in eng :d)
Solved! Go to Solution.
update JAVA > uninstall SUS/PCC > reinstall it > restart your PC > turn off your firewall and antivirus > run SUS and try again
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
