how do I get the original keyboard back?
I tryed swiftkey trial on my SE ray.
The trial period is just experied and now I cant get the original keyboard to work propperly again
There is no danish dictionary and I have to write with english spelling
Do anybody know how to get the original keyboard back?
PS: I was ok with Swiftkey eccept for there is no t9 mode when the phone is horisontal...
Pernille
backup everything and then update/repair your phone
Make sure you backup everything
Don't forget to mark the Correct Answers  & Helpful Answers
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
5 REPLIES 5
do you have the latest update 2.3.4? the reason I'm asking is because the new update comes with a gesture input/swype
go to settings -> about phone and check android version and build number
and also
or
How to install it
You need to
Contacts
open your phonebook
on your computer
Apps
SMS/MMS
or your SMS use
Call Logs
now on your phone
or
this is how to Update and/or Repair your phone, remember just uninstall the keyboard that you were using and that should bring the old keyboard back, or open any conversation -> tap on the input box -> once you see the keyboard -> long press on the input box -> input method -> international keyboard
also on the keyboard, tap on the wrench, but since you are using multiple languages it'll be a globe w/ a small wrench (bottom right corner of the keyboard) long press on it -> text input settings and select gesture input
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
don't forget to mark the Correct & Helpful Answers
Thank you very much for quick and correct help.
I repaired the phone, using your links etc.
Now I have the original keyboard back, and all my data(at least the data I know I would be missing if I lost it) is back.
I loooove my xperia ray!!!
Happy new year
Pernille
Anytime Slightly_smiling_Face
happy new year
