Xperia Mini SK15i/a 2.3.4 Update 4.0.2.A.0.42
Android 2.3.4 4.0.2.A.0.42
http://forum.xda-developers.com/showthread.php?t=1312475
Solved! Go to Solution.
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
W251bGwsMSwxLDEsImNvbS5tYWdtYW1vYmlsZS5hcHAuYXBraW5zdGFsbGVyIl0.
open "Apk Manager" and voila select the apps that you wan't to install
Easier method to install
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
go to settings -> applications -> check unknown sources
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
download FlashTool
http://forum.xda-developers.com/showthread.php?t=920746
or
http://androxyde.github.com/Flashtool/
Install it and you will see 5 folders
Custom
Drivers
Firmwares
Loaders
X10Flasher_lib
take the firmware to the "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
This is an step by step guide
or
now on your phone
Make sure you backup everything
Use this links to download the apk
or
How to install it
You need to
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
hi,
Thank u a lot!!!
but, what I want is "when I punch this code *#*#4636#*#*, I get options called battery details in that,
when battery temp. if it increases beyond 34'celsius it starts vibrating like morse code...."
other issue....
when I try updating my phone through PC COMPANION 2 I'm not able to.....
plz plz help...
use
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Thank u!!!!! Ur help for the update of phone really helped me a lot.....
Now,only one problem exists ie. am not able to find out y my phone starts vibrating like a "morse code"
plz plz help me out....
when does it vibrate? when you receive a call, sms, mms, etc?
hi,
No, It starts vibrating jst like that.... when I punch this code *#*#4636#*#* it shows me d battery temp as 34'C as soon it crosses this temp. it starts vibrating... I guess coz of exceeding battery temp or something else....
Anyways bye!!!!!
