Hi
I have set a lock screen wallpaper in my new Xperia U.
But I am not able to remove that only change option is there.
I have tried setting default theme to remove it. But still that lockscreen wallpaper is not removed....
Any one have any idea about this?
Regards
Jijesh
Solved! Go to Solution.
I suffered this dilemma too brother but then stumbled upon a simple solution...
jus change your current theme and the Lock Screen wallpaper will be gone.
Enjoy!!
no option to remove as such
Thank u JD_Thunder ......
It worked for me...
the problem was i was not changing the current theme... I just tried it with setting the same theme repeatedly....
Thank u.... thank u very much.....
You're welcome bro..:smileysilly:
I did the same but when I accidentally changed the theme I found out that it solved my li'l problem
i changed theme still same i cant get rid of the lock
Hi accyuklad,
kindly specify clearly what are you trying to get rid of ??
hi accyuklayed,
u wanna remove the lock screen wallpaper?
if so u may be selecting the same theme that u already selected.
Please select some other theme and it will solve the issue.
the lockscreen i already have a pattern password but before i enter that i after slide to unlock then do pattern password
im guessing i after download a theme to do this
I'm also having the same issue
After i set the pattern lock on my Xperia U, I cant get rid of it. In settings I can only choose between PIN, Password or Pattern lock, but the option None, Slide and Face Unlock is not available. It said: Disabled my administrator, encryption policy or credential storage.
How can I disable pattern lock? I just want to have standard unlock-camera screen, without password.
Thank' s for your help.
