hi
I have connected my xperia ray to laptp via usb cable. Now I can see some folders. Problem is when I copy and paste a theme folder from laptop to xperia, I can not find where it is saved? How can I find that?
Solved! Go to Solution.
I am very new to sonyerricsson and android. I hadn't experience with them before. Can you explain what is "sideload"? I want to paste appripriate files in their locations. For example, I want to receive some pictures via blue tooth or usb connection. I expect to see them in "gallery". The same is expected about themes, videos, ...
you can't install themes on this phone, the apps must be APK files, if you transfer pictures/videos through bluetooth they will be at the bluetooth folder
Don't forget to mark the Correct Answers & Helpful Answers
So, my friend send a file *.apk and my phone received it, but we don't know where it is!!
it depends how he send it, if it's to your gmail, open the gmail app -> then you can install it directly from here w/o downloading the app, if it's through MMS you have to long press on it -> save it, it will be saved on downloads, if it's through bluetooth it will be under the bluetooth folder.
go to the market and download OI File Manager
via bluetooth:
there is a bluetooth folder in gallery but it shows pictures only not theme (*.apk) files
yeah, if you look at my link above on how to sideload apps.
Download OI File Manager -> once you have it open it -> bluetooth folder -> tap on the apk and install it
guys,
I sent a file via bluetooth and as you can see in the picture, it says it is saved in /mnt/sdcard/bluetooth/
Now I want to know how can I access /mnt?
is it only accessable with OI file manager?
ok thanks a lot for your time
