hi
I have connected my xperia ray to laptp via usb cable. Now I can see some folders. Problem is when I copy and paste a theme folder from laptop to xperia, I can not find where it is saved? How can I find that?
Solved! Go to Solution.
Theme folder ?
Could you elaborate..
and you can't find it using pc or mobile ?
Try coplying it simply, copy the folder from pc and go to SD card ,create a new folder and paste in it
Please see the picture attached. Where should I put a new theme file (*.apk)?
Also what is the difference between "pictures" and "image" folders?
You can't install themes until you root your mobile
And you can send apk files anywhere, just paste it as it it here only, or create a folder and paste in it
here are some options on how to sideload apps
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
1- how can I be root?
2- if it is ok to paste anywahere, then where should I see on the phone? where are they?
Sorry how can that link help me?
Yes you can paste it anywhere..
If you don;t know what is root/rooting then i must say please don't use..
Could you tell me which theme are you willing to install ?
it seems that you are trying to sideload apps, right? there are alternatives.
Why not being root? I know that with administrative accesses, a mistake may happens, but I don't think changing a theme causes data loss.
my friend wants to send some themes. I don't know the names. Is it imporarnt? I will ask him
