my phone got into blind people(voice guidance) mode how to come out of it??
sony1315
my phone got into blind people(voice guidance) mode how to come out of it, i switched off my mobile even though it is in the same mode plz help me out as early as possible.
43 REPLIES 43
nikhita
Hi
 Thank you guys I was really tensed with this activation
you guys sloved it
NIKHITA
Adithya12345
It's simple
click google search on homepage and don't type speak talkback setting it will go to talkback setting there you can off talkback
killmatrix
thanks alot u saved me
Tags (1)
killmatrix
go to settings < acessibility<talkback<click on it press off . blind mode will be deactive
Kellz01
SOOOOOO grateful of this info I was about to burst into tears I don't even know how a blind person would benefit from those settings (I work with the blind and partially sighted) thank you for your help 🙂
Teskho13
Thankyou so much!!!!! Relieved to find this information and glad i managed to get rid of that!!
nwfxd52
I can't enter the phone unlock code in this mode. I have tried double-tapping each key but they just appear twice. It tells me that the pin is incorrect when I enter what I know is the correct pin. What can I try now?
Carmylynn
The double tapping to insert my password is not working what else can I do? I need to disable this talk on
mimimoal
How do I get the application for blind people off of my Moto X cell phone
Uliwooly
@mimimoal
settings > accessibility
