Pull-out tag inside micro SIM and micro SD slot
Karac
Hi there Slightly_smiling_Face
Just one little question. I just got my brand new T3 and when I was inserting the micro SIM card in it, I noticed little piece of paper sticking out of phone (from micro SIM and micro SD card slot). First time I see something like that. Some paper label with some information on it. And what I did !? As usually, without thinking... Pulled/ripped it out. Then I read on some forums, I shouldnt do that beacuse of that informations on it, etc... I dont care about that info, I only want to know is there any chance I did some damage to my phone by doing that !? It was pretty hard to get that paper out, like it was made of some thin plastic/paper matherial. Please someone answer so I dont worry about it anymore... Or should I worry !? Question
p.s. Sorry for bad english
Kind regards
Karac
5 REPLIES 5
Phy
Legend
Legend
It wasn't a piece of paper it was the IMEI information
http://support.sonymobile.com/global-en/xperiat3/userguide/IMEI-number/
Karac
Thanks for fast answer. So, any damage done to the phone ? IMEI, serial or whatever... I dont care about that. Just want to know if there is any chance I did some damage to the phone !? I hope not...
As I said, it was pretty hard to pull it out. And now of course I am little scared if I have done something to the phone...
Just got it and didnt think about consequences I could cause by pulling out that piece of paper...
Uliwooly
No one will be able to say if there's any damage or not unless you get it checked at your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
Bought2016
I had the same problem with my Xperia m4. Its very unclear!!!!
Mwara
I pulled my bit of paper out. What idiots putting a tiny piece of paper there.
